跳转到主内容
Dell Latitude E7440 Battery Replacement
你所需要的
  1. Dell Latitude E7440 Battery Replacement, Prepare the laptop: 步骤 1 中的图像 1,1
    • Power off your laptop before starting.
    • Flip the device over so that the vents on the bottom are facing away from you.
  2. Dell Latitude E7440 Battery Replacement, Release the battery: 步骤 2 中的图像 1,3 Dell Latitude E7440 Battery Replacement, Release the battery: 步骤 2 中的图像 2,3 Dell Latitude E7440 Battery Replacement, Release the battery: 步骤 2 中的图像 3,3
    • Place your finger on the latch located in the center of the laptop.
    • Slide the latch to the right, applying enough force to reveal a red indicator.
    • You will hear a soft click when the latch has been disengaged.
  3. Dell Latitude E7440 Battery Replacement, Remove the battery: 步骤 3 中的图像 1,1
    • Lift the battery by the top, away from the laptop body.
结论
8等其他人完成本指南。
Akash Kedia
于01/24/19注册
1,397 声望
创作了5篇指南
团队
Cal Poly, Team S2-G5, White Winter 2019 Cal Poly, Team S2-G5, White Winter 2019 的会员
CPSU-WHITE-W19S2G5
4 名成员
创作了5篇指南
2条评论
I wan to reconstruct this battery but I don’t find the model of the cells to be able to buy them…
Anwar Ben Tanfous - 回复
Any recommended site to buy original battery?
Razin Ahmed - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 69
总计 5,310
