跳转到主内容
Dell Latitude E7270 Fan Replacement
你所需要的
  1. Dell Latitude E7270 Fan Replacement, Back Panel: 步骤 1 中的图像 1,1
    • Place the device top down in front of you so that the vents are visible and are furthest from the user.
    • Please be sure that the device is powered off and unplugged before removing parts or deconstructing anything.
  2. Dell Latitude E7270 Fan Replacement: 步骤 2 中的图像 1,1
    • Remove all eight M2.5 X 8MM screws with a Phillips #00 screwdriver.
  3. Dell Latitude E7270 Fan Replacement: 步骤 3 中的图像 1,1
    • Lift and remove the panel.
  4. Dell Latitude E7270 Fan Replacement, Battery: 步骤 4 中的图像 1,1
    • Remove the three M2.5 X 5MM screws, located above the battery, with a Phillips #00 screwdriver.
  5. Dell Latitude E7270 Fan Replacement: 步骤 5 中的图像 1,1
    • Disconnect the battery wire by using your fingers to pull diagonally left on the tab.
  6. Dell Latitude E7270 Fan Replacement: 步骤 6 中的图像 1,1
    • Remove the battery completely by grabbing an edge and pulling up on the battery.
  7. Dell Latitude E7270 Fan Replacement, Cooling Fan: 步骤 7 中的图像 1,3 Dell Latitude E7270 Fan Replacement, Cooling Fan: 步骤 7 中的图像 2,3 Dell Latitude E7270 Fan Replacement, Cooling Fan: 步骤 7 中的图像 3,3
    • Remove the 4 pin fan power connector from the motherboard by using your finger and pulling up.
    • Remove the four M2.5 X 5MM screws that hold on the rectangular bracket located towards the center of the motherboard using a Phillips #00 screwdriver.
    • Remove the three M2.5 X 5MM screws that hold down the circular fan bracket using a Phillips #00 screwdriver.
  8. Dell Latitude E7270 Fan Replacement: 步骤 8 中的图像 1,1
    • Lift and remove fan by pulling gently straight up using your fingers
  9. Dell Latitude E7270 Fan Replacement: 步骤 9 中的图像 1,1
    • Before replacing fan, make sure to place a small amount of thermal paste to ensure proper heat dissipation and long term life.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 15
总计 1,229
