跳转到主内容
Dell Latitude E6540 Thermal paste Replacement
你所需要的
  1. Dell Latitude E6540 Thermal paste Replacement, Thermal paste: 步骤 1 中的图像 1,2 Dell Latitude E6540 Thermal paste Replacement, Thermal paste: 步骤 1 中的图像 2,2
    • First remove the 3 screws to remove the lead
  2. Dell Latitude E6540 Thermal paste Replacement: 步骤 2 中的图像 1,1
    • Then remove those 7 screws in order and try to keep track of which each screw place for when you assemble it back
  3. Dell Latitude E6540 Thermal paste Replacement: 步骤 3 中的图像 1,1
    • Carefully remove the fan connector
  4. Dell Latitude E6540 Thermal paste Replacement: 步骤 4 中的图像 1,1
    • carefully shake the heatsink until the thermal past loosens and it moves freely
  5. Dell Latitude E6540 Thermal paste Replacement: 步骤 5 中的图像 1,1
    • Now pull down the heat sink from its place
  6. Dell Latitude E6540 Thermal paste Replacement: 步骤 6 中的图像 1,1
    • Clean off the old thermal paste from the heat sink, CPU, and GPU, and then apply the new thermal paste
  7. Dell Latitude E6540 Thermal paste Replacement: 步骤 7 中的图像 1,1
    • put everything back into place, and don't forget to attack the connector to its place, and with that you are done
结论
Hunter
于09/17/24注册
145 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 19
总计 63
