跳转到主内容
Dell Latitude E6540 Base Cover and Base Cover Caps Replacement
你所需要的
  1. Dell Latitude E6540 Base Cover and Base Cover Caps Replacement, Remove screws: 步骤 1 中的图像 1,1
    • Before performing this task, make sure you turn off the computer and disconnect every external drive from it, whether it's a USB drive, power charger, or wireless adapter.
    • Remove the screws that secure the base cover to the computer.
  2. Dell Latitude E6540 Base Cover and Base Cover Caps Replacement, Remove base cover: 步骤 2 中的图像 1,1
    • Lift the base cover and remove it from the computer.
    • Place the base cover to align with the screw holes on the computer.
    • Tighten the screws to secure the base cover to the computer.
  3. Dell Latitude E6540 Base Cover and Base Cover Caps Replacement, Base Cover Caps - Step 1: 步骤 5 中的图像 1,1
    • You don't necessarily have to replace the base cover caps if you are just replacing the base cover itself.
    • Remove the screws that secure the left base corner cap, lift and remove it from the computer.
  4. Dell Latitude E6540 Base Cover and Base Cover Caps Replacement, Base Cover Caps - Step 2: 步骤 6 中的图像 1,1
    • Remove the screws that secure the right base corner cap, lift and remove it from the computer.
    • Place the left and right base corner caps to align with the screw holes on the computer.
    • Tighten the screws to secure the base corner caps to the computer.
结论
Hezekiah Brown
于02/11/21注册
6,169 声望
创作了49篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 257
