跳转到主内容
Dell Latitude E6530 Hard Drive Replacement
你所需要的
  1. Dell Latitude E6530 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip the computer over so that the bottom panel is facing you.
  2. Dell Latitude E6530 Hard Drive Replacement: 步骤 2 中的图像 1,2 Dell Latitude E6530 Hard Drive Replacement: 步骤 2 中的图像 2,2
    • Slide the switches away from each other to release the battery.
  3. Dell Latitude E6530 Hard Drive Replacement: 步骤 3 中的图像 1,2 Dell Latitude E6530 Hard Drive Replacement: 步骤 3 中的图像 2,2
    • Using your hands, gently remove the battery from the device.
  4. Dell Latitude E6530 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 1,2 Dell Latitude E6530 Hard Drive Replacement, Hard Drive: 步骤 4 中的图像 2,2
    • Using a Phillips #00 screwdriver, unscrew the two screws.
  5. Dell Latitude E6530 Hard Drive Replacement: 步骤 5 中的图像 1,2 Dell Latitude E6530 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Gently remove the hard drive.
  6. Dell Latitude E6530 Hard Drive Replacement: 步骤 6 中的图像 1,1
    • Undo the Phillips #1 screw keeping the drive in the bracket.
  7. Dell Latitude E6530 Hard Drive Replacement: 步骤 7 中的图像 1,1
    • Remove the drive from the bracket,
结论
To reassemble your device, follow these instructions in reverse order. Refer to the troubleshooting guide and additional links for more information if issue persists.
一条评论
There’s a missing step here. There’s another screw you’re supposed to undo to remove the drive.
Ella - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 38
总计 1,025
