跳转到主内容
Dell Latitude E6530 Fan & Heatsink Replacement
你所需要的
  1. Dell Latitude E6530 Fan & Heatsink Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip over the laptop.
  2. Dell Latitude E6530 Fan & Heatsink Replacement: 步骤 2 中的图像 1,1
    • Pull back the 2 battery tabs which are to the left and the right of the battery.
  3. Dell Latitude E6530 Fan & Heatsink Replacement: 步骤 3 中的图像 1,1
    • Remove the battery from the laptop.
  4. Dell Latitude E6530 Fan & Heatsink Replacement, Bottom Cover: 步骤 4 中的图像 1,1
    • Remove the 4 Philips #0 screws from the laptop.
  5. Dell Latitude E6530 Fan & Heatsink Replacement: 步骤 5 中的图像 1,1
    • Remove the bottom cover from the laptop.
  6. Dell Latitude E6530 Fan & Heatsink Replacement, Heatsink: 步骤 6 中的图像 1,1
    • Remove the fan connector.
  7. Dell Latitude E6530 Fan & Heatsink Replacement: 步骤 7 中的图像 1,1
    • Remove the 4 Philips #1 screws on the heatsink.
  8. Dell Latitude E6530 Fan & Heatsink Replacement: 步骤 8 中的图像 1,1
    • Remove the Fan+Heatsink assembly.
  9. Dell Latitude E6530 Fan & Heatsink Replacement: 步骤 9 中的图像 1,2 Dell Latitude E6530 Fan & Heatsink Replacement: 步骤 9 中的图像 2,2
    • Use a paper towel or alcohol swab to clean the thermal paste from the heatsink & CPU.
结论
To reassemble your device, follow these instructions in reverse order. Remember to apply the thermal paste on the CPU!
3等其他人完成本指南。
Ella
于08/26/19注册
2,221 声望
创作了10篇指南
2条评论
The Amazon link above no longer works (404).
It's important to note that there are two different heatsinks depending on the type of GPU equipped in the system
* Lattitude E6530 with Intel UMA Integrated Video uses Dell 2MK5J heatsink / fan assembly as shown in the guide
* Those with Discrete Nvidia use Dell M2CFG with can be differentiated by the two heat sinks and two copper heat pipes.
Dell doesn't list these parts for sale (Jan 2023) though used ones are listed on eBay.
Mike Verstegen - 回复
Yes, I just saw one for sale on eBay (the M2CFG)
bk_qb - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 33
总计 2,260
