跳转到主内容
Dell Latitude E6530 CPU Replacement
你所需要的
  1. Dell Latitude E6530 CPU Replacement, Battery: 步骤 1 中的图像 1,1
    • Flip over the laptop.
  2. Dell Latitude E6530 CPU Replacement: 步骤 2 中的图像 1,1
    • Pull back the 2 battery tabs which are to the left and the right of the battery.
  3. Dell Latitude E6530 CPU Replacement: 步骤 3 中的图像 1,1
    • Remove the battery from the laptop.
  4. Dell Latitude E6530 CPU Replacement, Bottom Cover: 步骤 4 中的图像 1,1
    • Remove the 4 Philips #0 screws from the laptop.
  5. Dell Latitude E6530 CPU Replacement: 步骤 5 中的图像 1,1
    • Remove the bottom cover from the laptop.
  6. Dell Latitude E6530 CPU Replacement, Heatsink: 步骤 6 中的图像 1,1
    • Remove the fan connector.
  7. Dell Latitude E6530 CPU Replacement: 步骤 7 中的图像 1,1
    • Remove the 4 Philips #1 screws on the heatsink.
  8. Dell Latitude E6530 CPU Replacement: 步骤 8 中的图像 1,1
    • Remove the Fan+Heatsink assembly.
  9. Dell Latitude E6530 CPU Replacement: 步骤 9 中的图像 1,2 Dell Latitude E6530 CPU Replacement: 步骤 9 中的图像 2,2
    • Use a paper towel or alcohol swab to clean the thermal paste from the heatsink & CPU.
  10. Dell Latitude E6530 CPU Replacement, CPU: 步骤 10 中的图像 1,2 Dell Latitude E6530 CPU Replacement, CPU: 步骤 10 中的图像 2,2
    • Use a flathead screwdriver and turn the CPU lock counter-clockwise.
    • Remember to turn the CPU Lock clockwise when you install the new CPU! If you don't do this, the computer won't boot up.
  11. Dell Latitude E6530 CPU Replacement: 步骤 11 中的图像 1,1
    • Carefully remove the CPU.
    • Be VERY CAREFUL to NOT bend ANY pins on the CPU.
结论
To reassemble your device, follow these instructions in reverse order. Remember to reapply the thermal paste!
2等其他人完成本指南。
Ella
于08/26/19注册
2,221 声望
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 26
总计 1,178
