简介
The LCD (liquid crystal display) screen may need to be replaced if it is cracked or to improve resolution.
你所需要的
With the laptop closed and the bottom side facing up, slide the two battery latches towards the sides of the laptop.
Gently pry the protective LCD cover from around the screen. You shouldn't have a problem just using your fingers.
即将完成!
结论
另外一个人完成了本指南。
