跳转到主内容
Dell Latitude E6510 RAM Replacement
你所需要的
  1. Dell Latitude E6510 RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Use a J1 screwdriver to remove the 8mm screw on the bottom cover.
  2. Dell Latitude E6510 RAM Replacement: 步骤 2 中的图像 1,1
    • Unclasp and pull the memory card up.
    • Be careful when unclasping and releasing the memory card. Clasps are fragile.
结论
3等其他人完成本指南。
Kolin Doyle
于11/06/17注册
500 声望
创作了4篇指南
团队
Baylor, Team S8-G4, Johnson Fall 2017 Baylor, Team S8-G4, Johnson Fall 2017 的会员
BU-JOHNSON-F17S8G4
1 名成员
创作了4篇指南
一条评论
There should be four steps to this, step two should be removing the 4 hard drive screws,
step three should be removing the bottom cover, including that it slides off, as many bottom covers snap in.
I almost damaged the bottom cover trying to pry it up.
Brian Barlow - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 11
总计 1,945
