跳转到主内容
Dell Latitude E6510 USB Ports Replacement
你所需要的
  1. 注意:步骤 1-3 源自标记为进行中的 指南
    Dell Latitude E6510  USB Ports Replacement, Fan: 步骤 1 中的图像 1,2 Dell Latitude E6510  USB Ports Replacement, Fan: 步骤 1 中的图像 2,2
    • Slide the two black clips toward the middle to release battery
  2. Dell Latitude E6510  USB Ports Replacement: 步骤 2 中的图像 1,2 Dell Latitude E6510  USB Ports Replacement: 步骤 2 中的图像 2,2
    • Remove the back plate from the back of the device
    • Remove the 6 screws with the J1 screwdriver.
    • once the screws are out, slide back panel towards front of the device and lift up
  3. Dell Latitude E6510  USB Ports Replacement: 步骤 3 中的图像 1,3 Dell Latitude E6510  USB Ports Replacement: 步骤 3 中的图像 2,3 Dell Latitude E6510  USB Ports Replacement: 步骤 3 中的图像 3,3
    • Remove two screws holding the fan
    • Slide from under copper heat sink
    • Unplug connector and remove
    • To reassemble, follow directions in reverse
  4. Dell Latitude E6510  USB Ports Replacement, USB Ports: 步骤 4 中的图像 1,2 Dell Latitude E6510  USB Ports Replacement, USB Ports: 步骤 4 中的图像 2,2
    • Remove the battery
    • Flip the computer so that it is facing downward.
    • Next locate the two black clips as shown in the image.
    • Slide the clips toward the middle in order to release the battery.
  5. Dell Latitude E6510  USB Ports Replacement: 步骤 5 中的图像 1,3 Dell Latitude E6510  USB Ports Replacement: 步骤 5 中的图像 2,3 Dell Latitude E6510  USB Ports Replacement: 步骤 5 中的图像 3,3
    • Remove the back plate from the back of the device.
    • Using the Philips head screwdriver remove the 6 screws marked in red.
    • Next, slide the panel down and then lift up til completely removed.
  6. Dell Latitude E6510  USB Ports Replacement: 步骤 6 中的图像 1,3 Dell Latitude E6510  USB Ports Replacement: 步骤 6 中的图像 2,3 Dell Latitude E6510  USB Ports Replacement: 步骤 6 中的图像 3,3
    • Press the button on the side of the optical drive in order to release the pull tab.
    • Next, pull out the optical drive located on the lower left hand side.
    • Locate the hard drive on the lower right hand side and remove it from the computer.
  7. Dell Latitude E6510  USB Ports Replacement: 步骤 7 中的图像 1,3 Dell Latitude E6510  USB Ports Replacement: 步骤 7 中的图像 2,3 Dell Latitude E6510  USB Ports Replacement: 步骤 7 中的图像 3,3
    • Using the Philips head screwdriver unscrew the two screws holding the fan.
    • Next, slide the fan out from under the copper heat sink.
    • Unplug the connector marked in blue and remove the fan.
  8. Dell Latitude E6510  USB Ports Replacement: 步骤 8 中的图像 1,2 Dell Latitude E6510  USB Ports Replacement: 步骤 8 中的图像 2,2
    • Using the Philips head screwdriver unscrew the seven screws holding down the copper heat sink.
    • Lift the heat sink slightly and slide out to remove it.
  9. Dell Latitude E6510  USB Ports Replacement: 步骤 9 中的图像 1,3 Dell Latitude E6510  USB Ports Replacement: 步骤 9 中的图像 2,3 Dell Latitude E6510  USB Ports Replacement: 步骤 9 中的图像 3,3
    • Using a spudger remove the volume bar above the keyboard
    • Using the Philips head screwdriver unscrew the two screws near the top of the keyboard.
    • Lift the keyboard membrane slightly by tab, and slide the keyboard towards the screen in order to remove.
    • Using the Philips head screwdriver unscrew the three screws marked in green.
  10. Dell Latitude E6510  USB Ports Replacement: 步骤 10 中的图像 1,1
    • Using the Philip head screwdriver unscrew the eight screws holding down the chassis to get to the USB ports.
  11. Dell Latitude E6510  USB Ports Replacement: 步骤 11 中的图像 1,1
    • Remove the USB port by using a soldering iron to take out the connections on either side of the port.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 1,364
