简介
The prerequisite guide that is recommended to read before this guide will cover removing the fan from a Dell Latitude E6510.
This guide will cover how to replace the USB ports whether they are damaged or you are replacing them as a precautionary item. The product is the Dell Latitude E6510 computer.
Before using this guide make sure that the computer is powered off and that you have a clean workspace in which it is easy to keep track of all parts.
This guide requires you to know how to use a soldering iron safely as well as having a basic knowledge of how to use tools like a screwdriver.
你所需要的
Remove the battery
Flip the computer so that it is facing downward.
Next locate the two black clips as shown in the image.
Slide the clips toward the middle in order to release the battery.
Using a spudger remove the volume bar above the keyboard
Using the Philips head screwdriver unscrew the two screws near the top of the keyboard.
Lift the keyboard membrane slightly by tab, and slide the keyboard towards the screen in order to remove.
Using the Philips head screwdriver unscrew the three screws marked in green.
