简介
In this section, you will observe how to very easily remove a damaged or malfunctioning keyboard. This breakdown of components can be done with ease: simply follow each step using the required tools. Tools needed are:
- Spudger
- Screwdriver
- Bit J00
你所需要的
Locate the keyboard and the led display cover.
Using the prying tool, go to the furthest right side of the keyboard cover and wedge upwards to lift the component out.
Locate the two M2.5X5mm screws and loosen using the J00 bit.
3等其他人完成本指南。
