跳转到主内容
Dell Latitude E6510 Heat Sink Replacement
你所需要的
  1. Dell Latitude E6510  Heat Sink Replacement, Heat Sink: 步骤 1 中的图像 1,3 Dell Latitude E6510  Heat Sink Replacement, Heat Sink: 步骤 1 中的图像 2,3 Dell Latitude E6510  Heat Sink Replacement, Heat Sink: 步骤 1 中的图像 3,3
    • Locate the tabs that lock the battery in place.
    • Push tabs towards each other while simultaneously pushing the battery away from the device.
  2. Dell Latitude E6510  Heat Sink Replacement: 步骤 2 中的图像 1,3 Dell Latitude E6510  Heat Sink Replacement: 步骤 2 中的图像 2,3 Dell Latitude E6510  Heat Sink Replacement: 步骤 2 中的图像 3,3
    • Unscrew the screw located in the center of the back panel. Do not completely remove the screw, a spring will keep it in place when it has been loosened.
    • Slide the panel back until it unlocks.
  3. Dell Latitude E6510  Heat Sink Replacement: 步骤 3 中的图像 1,3 Dell Latitude E6510  Heat Sink Replacement: 步骤 3 中的图像 2,3 Dell Latitude E6510  Heat Sink Replacement: 步骤 3 中的图像 3,3
    • Locate the fan plug.
    • Pull up until it is unplugged from the reciever.
    • Take caution when unplugging the fan plug from the receiver.
  4. Dell Latitude E6510  Heat Sink Replacement: 步骤 4 中的图像 1,3 Dell Latitude E6510  Heat Sink Replacement: 步骤 4 中的图像 2,3 Dell Latitude E6510  Heat Sink Replacement: 步骤 4 中的图像 3,3
    • Unscrew the two 5.5 mm screws securing the fan.
    • Lift the end of the fan opposite the copper wire up.
    • Pull the fan away from the device.
  5. Dell Latitude E6510  Heat Sink Replacement: 步骤 5 中的图像 1,1
    • Locate and loosen the four silver screws holding down the heat redistribute component.
    • Do not competely remove the screws as springs keep the screws attached to the metal plate after you loosen them.
  6. Dell Latitude E6510  Heat Sink Replacement: 步骤 6 中的图像 1,3 Dell Latitude E6510  Heat Sink Replacement: 步骤 6 中的图像 2,3 Dell Latitude E6510  Heat Sink Replacement: 步骤 6 中的图像 3,3
    • Lift the metal plate up on the end closest to the screws.
    • Slide the whole assembly away from where you removed the fan.
结论
2等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 20
总计 955
