跳转到主内容
Dell Latitude E6420 Wireless Card Replacement
你所需要的
  1. Dell Latitude E6420 Wireless Card Replacement, Battery: 步骤 1 中的图像 1,2 Dell Latitude E6420 Wireless Card Replacement, Battery: 步骤 1 中的图像 2,2
    • Push the tabs on the left and right of the battery out towards the edge of the case.
  2. Dell Latitude E6420 Wireless Card Replacement: 步骤 2 中的图像 1,1
    • While still pushing in the tabs, using your pinky finger, lift the battery out of the laptop.
  3. Dell Latitude E6420 Wireless Card Replacement, CD/DVD Drive: 步骤 3 中的图像 1,2 Dell Latitude E6420 Wireless Card Replacement, CD/DVD Drive: 步骤 3 中的图像 2,2
    • Push the button in on the CD/DVD drive to eject the drive.
  4. Dell Latitude E6420 Wireless Card Replacement: 步骤 4 中的图像 1,2 Dell Latitude E6420 Wireless Card Replacement: 步骤 4 中的图像 2,2
    • Slide the drive out of the laptop.
    • When removing the drive, keep it flat to prevent damage to anything inside the laptop.
  5. Dell Latitude E6420 Wireless Card Replacement, Backplate: 步骤 5 中的图像 1,2 Dell Latitude E6420 Wireless Card Replacement, Backplate: 步骤 5 中的图像 2,2
    • Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
    • Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
  6. Dell Latitude E6420 Wireless Card Replacement: 步骤 6 中的图像 1,2 Dell Latitude E6420 Wireless Card Replacement: 步骤 6 中的图像 2,2
    • Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
    • Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
  7. Dell Latitude E6420 Wireless Card Replacement, Wireless Card: 步骤 7 中的图像 1,2 Dell Latitude E6420 Wireless Card Replacement, Wireless Card: 步骤 7 中的图像 2,2
    • Using the screwdriver, remove two 4mm JIS #0 screws.
  8. Dell Latitude E6420 Wireless Card Replacement: 步骤 8 中的图像 1,3 Dell Latitude E6420 Wireless Card Replacement: 步骤 8 中的图像 2,3 Dell Latitude E6420 Wireless Card Replacement: 步骤 8 中的图像 3,3
    • Disconnect 4 wires by pulling upward.
    • Gently remove the wires to prevent damaging them.
  9. Dell Latitude E6420 Wireless Card Replacement: 步骤 9 中的图像 1,1
    • Lift the wiring harness out of the way.
  10. Dell Latitude E6420 Wireless Card Replacement: 步骤 10 中的图像 1,3 Dell Latitude E6420 Wireless Card Replacement: 步骤 10 中的图像 2,3 Dell Latitude E6420 Wireless Card Replacement: 步骤 10 中的图像 3,3
    • The card will lift up, remove the card by pulling the lifted edge away from you.
结论
2等其他人完成本指南。
Madysen Eames
于02/27/18注册
1,528 声望
创作了7篇指南
团队
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 27
总计 1,929
