当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Open the laptop and lay it flat on your work surface.
Using the spudger, lift the bezel up from around the laptop screen.
Using the screwdriver, remove four 5mm Phillips #0 screws from the bottom of the laptop screen.
Using the screwdriver, remove two 3mm Phillips #0 screws from the top of the laptop screen.
Lift the screen.
Lift the piece of tape attached to the LCD cable.
Once the tape has lifted, gently pull back to unplug the LCD cable.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
