简介
If the fan isn't working properly, the laptop can overheat. This guide will show users how to replace the fan.
你所需要的
Push the tabs on the left and right of the battery out towards the edge of the case.
Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
4等其他人完成本指南。
一条评论
very good explanatory steps. but you did not talk about the application of thermal paste for reassembly
