跳转到主内容
Dell Latitude E6420 CPU Replacement
你所需要的
  1. Dell Latitude E6420 CPU Replacement, Rear Panel Removal: 步骤 1 中的图像 1,2 Dell Latitude E6420 CPU Replacement, Rear Panel Removal: 步骤 1 中的图像 2,2
    • Remove the eight screws holding down the rear panel using a Phillips #0 Screwdriver. Carefully remove base cover by hand.
  2. Dell Latitude E6420 CPU Replacement, CPU: 步骤 2 中的图像 1,1
    • Remove the battery by pushing the tabs outward, then removing the battery from the device.
  3. Dell Latitude E6420 CPU Replacement: 步骤 3 中的图像 1,1
    • Remove the four screws securing the heatsink using the Phillips #0 screwdriver.
    • Remove the heatsink and fan assembly.
  4. Dell Latitude E6420 CPU Replacement: 步骤 4 中的图像 1,1
    • Use the flat end of a spudger to rotate the lock 180 degrees counterclockwise to unlock the CPU.
  5. Dell Latitude E6420 CPU Replacement: 步骤 5 中的图像 1,2 Dell Latitude E6420 CPU Replacement: 步骤 5 中的图像 2,2
    • Lift the CPU out of the motherboard assembly.
结论
6等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 38
总计 3,197
