当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Slide the drive out of the laptop.
When removing the drive, keep it flat to prevent damage to anything inside the laptop.
Using the screwdriver, remove seven 4mm Phillips #1 screws from the bottom of the laptop.
Using the screwdriver, remove two 9mm Phillips #00 screws from the bottom of the laptop.
Gently lift the back plate off of the laptop making sure all of the tabs on the inside perimeter of the back plate are unhooked before lifting.
Be careful when removing the backplate. Lifting the backplate while the tabs are still hooked in will result in broken tabs.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
