简介
Use this guide to replace the entire Dell Latitude e6410 screen assembly. You will be removing the entire old screen assembly and replacing it with the new screen.
Use this guide only to replace the entire screen assembly. "Screen assembly" refers to the all of the screen components fully assembled into the screen case including the display, camera, and other components.
你所需要的
Slide both clips in towards each other to remove the battery from the laptop.
Remove the two 5mm Phillip's screws in the bottom right and the top left corners of the back panel.
Remove the 3mm Phillip's screw that is near the bottom right corner.
Loosen the Phillip's screw that is near the center until the spring pops up, but do not remove it.
Detach the back case panel by sliding it away from the battery slot and lifting it out of place.
10等其他人完成本指南。
