当前版本的文档还未经巡查,您可以查看最新的已查核版本。
你所需要的
这个步骤还没有翻译 帮忙翻译一下
Loosen screw 1
Do not completely loosen a screw.
Loosen each screw a little bit. Going from 1 then to 2 then to 3 and then to 4. Keep doing this until they are all loose.
Loosening one completely with out the other screws loosened may damage the logic board
Lift the heatsink up, until it won't rise any farther.
Pull the heat sink out.
这个步骤还没有翻译 帮忙翻译一下
Using cotton swabs, clean off the old thermal paste off the die of the CPU and the heat sink.
Use the strongest isopropyl alcohol you can find.
You want to dip the cotton swabs into the alcohol and clean off the paste.
Keep doing this until the white cotton remains white. this indicates it is as clean as possible.
Dry the heat sink and die with another cotton swab. Make sure than none of the carbon fibers are left on the die or copper plating.
11等其他人完成本指南。
3条评论
Followed this guide hoping to reduce the loud fan noise from my E6400. You missed out the important step of applying new thermal paste after removing the old stuff. Also, you don't mention the other two chips under the heatsink (presume the GPU and northbridge/chipset). On mine these had spongy, compressible pads where I would have expected thermal paste or a thermal sticker. I wasn't sure whether to remove these or not, since they are quite thick - it seemed unlikely that normal thermal paste could bridge the gap. After putting everything back together the machine is still very noisy so it seems that the cpu temperature is not causing the high fan speed.
Step 4 shows how to clean the old thermal paste off the processor. The rubber squares are thermal pads. Take care not to rip or damage them, or they will need to be replaced.
