跳转到主内容
配件
没有特定配件。
  1. Dell Latitude E6400 CPU Replacement, Battery Removal: 步骤 1 中的图像 1,3 Dell Latitude E6400 CPU Replacement, Battery Removal: 步骤 1 中的图像 2,3 Dell Latitude E6400 CPU Replacement, Battery Removal: 步骤 1 中的图像 3,3
    • Disconnect AC power adaptor
    • Push battery release tabs inwards.
    • Slide the battery out of the computer.
  2. Dell Latitude E6400 CPU Replacement, Bottom Lid: 步骤 2 中的图像 1,2 Dell Latitude E6400 CPU Replacement, Bottom Lid: 步骤 2 中的图像 2,2
    • Remove the one 7.5 mm Phillips screw securing the bottom case.
    • Pull the bottom lid towards yourself to remove it.
  3. Dell Latitude E6400 CPU Replacement, Fan: 步骤 3 中的图像 1,3 Dell Latitude E6400 CPU Replacement, Fan: 步骤 3 中的图像 2,3 Dell Latitude E6400 CPU Replacement, Fan: 步骤 3 中的图像 3,3
    • Remove the two 4.8mm Phillips screws securing the fan.
    • Disconnect the fan by pulling power cable straight up.
    • Lift the fan with your finger and slide it out towards the inside of the laptop.
  4. Dell Latitude E6400 CPU Replacement, Heat Sink: 步骤 4 中的图像 1,2 Dell Latitude E6400 CPU Replacement, Heat Sink: 步骤 4 中的图像 2,2
    • Remove the four Phillips screws securing the heat sink.
    • Using your finger gently lift and remove heat sink .
  5. Dell Latitude E6400 CPU Replacement: 步骤 5 中的图像 1,1
    • Gently rotate left the locking screw to release CPU from its socket.
    • Lift the CPU straight up of it's socket.
结论
D. K. Labudek
于2018年03月09日注册
685 声望分
创作了4篇指南
0条评论
添加评论
浏览统计数据:
过去的24小时: 1
过去的7天: 2
过去的30天: 4
总计 35
