跳转到主内容
Dell Latitude E5500 Wireless Card Replacement
你所需要的
  1. Dell Latitude E5500 Wireless Card Replacement, Wireless Card: 步骤 1 中的图像 1,1
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 Wireless Card Replacement: 步骤 2 中的图像 1,2 Dell Latitude E5500 Wireless Card Replacement: 步骤 2 中的图像 2,2
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 Wireless Card Replacement: 步骤 3 中的图像 1,2 Dell Latitude E5500 Wireless Card Replacement: 步骤 3 中的图像 2,2
    • The wireless card is located near the front of the device, and is the expansion card with three antennas attached to it.
  4. Dell Latitude E5500 Wireless Card Replacement: 步骤 4 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the wires connecting the card to the laptop with a pair of tweezers.
  5. Dell Latitude E5500 Wireless Card Replacement: 步骤 5 中的图像 1,1
    • Unscrew the 4mm Phillips #1 screw that secure the card in place.
  6. Dell Latitude E5500 Wireless Card Replacement: 步骤 6 中的图像 1,2 Dell Latitude E5500 Wireless Card Replacement: 步骤 6 中的图像 2,2
    • After completing steps 4 & 5, the card will lift up at an angle as shown.
    • Once the card has popped out of place, it can be gently removed.
结论
3等其他人完成本指南。
Richard Harrison
于10/23/16注册
805 声望
创作了4篇指南
团队
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 UMass Dartmouth, Team 2-4, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S2G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 55
总计 1,385
