跳转到主内容
Dell Latitude E5500 RAM Replacement
你所需要的
  1. Dell Latitude E5500 RAM Replacement, RAM: 步骤 1 中的图像 1,1
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 RAM Replacement: 步骤 2 中的图像 1,2 Dell Latitude E5500 RAM Replacement: 步骤 2 中的图像 2,2
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 RAM Replacement: 步骤 3 中的图像 1,1
    • The RAM sticks are located near the center of the device, and are arranged one on top of the other.
  4. Dell Latitude E5500 RAM Replacement: 步骤 4 中的图像 1,2 Dell Latitude E5500 RAM Replacement: 步骤 4 中的图像 2,2
    • Locate the two dislocating tabs on each side of the stick and place your fingers on the tabs.
    • Pull the tabs away from the stick to pop it out of place.
    • Notice the angle it rests at after the tabs have been opened. This is important for installation of new RAM.
    • Once the RAM stick has popped out of place, it can be gently removed.
  5. Dell Latitude E5500 RAM Replacement: 步骤 5 中的图像 1,3 Dell Latitude E5500 RAM Replacement: 步骤 5 中的图像 2,3 Dell Latitude E5500 RAM Replacement: 步骤 5 中的图像 3,3
    • If necessary, repeat this process with the second RAM stick that lies beneath the first one.
结论
To reassemble your device, install the new stick(s) and follow these instructions in reverse order.
4等其他人完成本指南。
Evan Eldridge
于10/20/16注册
215 声望
撰写一个指南
团队
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 UMass Dartmouth, Team 2-4, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S2G4
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 21
总计 2,106
