跳转到主内容
Dell Latitude E5500 Cooling Fan Replacement
你所需要的
  1. Dell Latitude E5500 Cooling Fan Replacement, Cooling Fan: 步骤 1 中的图像 1,1
    • Unscrew the single 3.5mm Phillips #1 screw that holds on the bottom plate of the device.
  2. Dell Latitude E5500 Cooling Fan Replacement: 步骤 2 中的图像 1,2 Dell Latitude E5500 Cooling Fan Replacement: 步骤 2 中的图像 2,2
    • Place your hands on the plate and pull it toward yourself.
    • The plate will pop out of place and may then be removed.
  3. Dell Latitude E5500 Cooling Fan Replacement: 步骤 3 中的图像 1,1
    • The cooling fan is located near the edge of the device, on the side with the vent, and is contained within a plastic shroud.
  4. Dell Latitude E5500 Cooling Fan Replacement: 步骤 4 中的图像 1,3 Dell Latitude E5500 Cooling Fan Replacement: 步骤 4 中的图像 2,3 Dell Latitude E5500 Cooling Fan Replacement: 步骤 4 中的图像 3,3
    • Unscrew the two 9mm Phillips #1 screws that secure the fan in place.
    • Disconnect the fan header from the motherboard of the laptop.
    • The fan header has many small wires sleeved together. To avoid ripping the wires out of the connector, wiggle the connector out of place instead of pulling straight up on it.
  5. Dell Latitude E5500 Cooling Fan Replacement: 步骤 5 中的图像 1,1
    • Remove the fan from its housing.
    • The fan may be difficult to get out of the housing, as it is surrounded on three sides by the housing itself and the heatsink. It is not glued or taped in, however, so you can gently pull the cord you just disconnected up to remove the fan from the housing without risk of damaging the cord.
结论
2等其他人完成本指南。
Richard Harrison
于10/23/16注册
805 声望
创作了4篇指南
团队
UMass Dartmouth, Team 2-4, Isaacson Fall 2016 UMass Dartmouth, Team 2-4, Isaacson Fall 2016 的会员
UMASSD-ISAACSON-F16S2G4
3 名成员
创作了5篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 26
总计 1,634
