跳转到主内容
Dell Latitude E5470 LC-Display Panel Replacement
你所需要的
  1. Dell Latitude E5470 LC-Display Panel Replacement, Bottom cover removal: 步骤 1 中的图像 1,2 Dell Latitude E5470 LC-Display Panel Replacement, Bottom cover removal: 步骤 1 中的图像 2,2
    • Loosen the 8 screws on the bottom cover. The screws will remain in the casing, they do not come out all the way.
    • Insert the pick or spudger between the upper and lower casing to release the plastic clips.
    • Attention needed: The clips are easily broken.
  2. Dell Latitude E5470 LC-Display Panel Replacement, Disconnect the battery: 步骤 2 中的图像 1,1
    • To disconnect the battery, pull gently upwards on the tab connector.
  3. Dell Latitude E5470 LC-Display Panel Replacement, Remove the LCD Bezel: 步骤 3 中的图像 1,1
    • Using a pick or spudger, gently insert between the LCD back-cover and bezel to release the clips.
    • The bezel is also glued to the LCD panel.
    • Remove slowly to avoid tearing or damaging any components underneath.
  4. Dell Latitude E5470 LC-Display Panel Replacement, Removing the LCD panel: 步骤 4 中的图像 1,1
    • Remove the 4 Philips screws securing the panel.
  5. Dell Latitude E5470 LC-Display Panel Replacement, Remove the LCD Connector: 步骤 5 中的图像 1,3 Dell Latitude E5470 LC-Display Panel Replacement, Remove the LCD Connector: 步骤 5 中的图像 2,3 Dell Latitude E5470 LC-Display Panel Replacement, Remove the LCD Connector: 步骤 5 中的图像 3,3
    • Remove the LCD paneland lay it flat on the keyboard.
    • You will be able to see the connector on the back of the LCD panel secured with some adhesive tape and a metal connector.
    • Udsing the tweezers, slowly lift the tape away to reveal the blue sticky protector. Removing the blue pad to see the metal connector underneath.
    • Using a spudger, lift the front of the connector up (highlighted by the white arrow).
    • Pull the cable back to release the cable from the connector.
    • To reassemble, follow the steps in reverse.
结论
4等其他人完成本指南。
Harvey
于02/15/16注册
5,193 声望
创作了10篇指南
5条评论
Your presentation is perfect
sachida1986niit - 回复
Thanks very much :)
Harvey - 回复
Hello, will this model with touch screen work with non touch replacement LCD?
cellularcircuit - 回复
Damaged touch lcd and was not using touch , want to save some $ by installing not touch lcd..
cellularcircuit -
Thanks - seems that little piece of blue sticky protector was my whole problem, months of a flickering screen, that was temporarily fixed upon pressing on the bottom of the bezel. Upon opening up the screen, it was crooked. So I straightened it, put things back together, and the flickering seems to be gone. Cross my fingers!
Peter Lyons - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 47
总计 8,485
