跳转到主内容
Dell Latitude E5450-5450 Wifi Card Replacement
你所需要的
  1. Dell Latitude E5450-5450 Wifi Card Replacement, Wifi Card: 步骤 1 中的图像 1,1
    • Remove the 6 screws using a Philips #1 (PH1) screwdriver.
  2. Dell Latitude E5450-5450 Wifi Card Replacement: 步骤 2 中的图像 1,1
    • Using your fingers or a pry tool, gently lift the cover from the device. If the device has been opened before, it should open easily from the top corner using your finger.
    • If it is a tight fit, a spudger can be used to gently pry open the cover. Place the spudger at the top corner to pry open.
  3. Dell Latitude E5450-5450 Wifi Card Replacement: 步骤 3 中的图像 1,1
    • Disconnect the battery before proceeding to reduce the risk of shock or damage.
    • Gently pull the tab attached to the battery to disconnect it.
  4. Dell Latitude E5450-5450 Wifi Card Replacement: 步骤 4 中的图像 1,1
    • If the wires are not clearly labeled as 1 and 2, take note of how the wires are connected to know which is 1 and 2. The WiFi card should have a tiny 1 and 2 on the card itself for guidance.
  5. Dell Latitude E5450-5450 Wifi Card Replacement: 步骤 5 中的图像 1,1
    • Use a Philips #1 (PH1) screwdriver to remove the screw holding the WiFi card in place.
  6. Dell Latitude E5450-5450 Wifi Card Replacement: 步骤 6 中的图像 1,1
    • Gently disconnect the antennas and slide the WiFi card from the slot
  7. 在这个步骤中使用的工具:
    • Slide new WiFi card into the slot and reassemble the device by completing steps 1-6 in reverse order.
    • You might need to use tweezers to hold the cables in place as you connect the antenna to the WiFi card. A spudger can be used to gently press the connectors into place.
结论
团队
Ethical Culture Fieldston School Ethical Culture Fieldston School 的会员
Business
3 名成员
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 26
总计 1,212
