跳转到主内容
Dell Latitude E5430 Hard Drive Replacement
你所需要的
  1. Dell Latitude E5430 Hard Drive Replacement, Remove the Battery: 步骤 1 中的图像 1,1
    • Slide the two notches outward. Lift the battery outward and pull.
  2. Dell Latitude E5430 Hard Drive Replacement, Remove the Bottom Cover: 步骤 2 中的图像 1,1
    • Remove two Phillips head screws from the bottom cover.
  3. Dell Latitude E5430 Hard Drive Replacement, Remove the Hard Drive Caddy: 步骤 3 中的图像 1,1
    • Remove the four Phillips head screws from the hard drive caddy.
    • System memory (RAM) is located here.
    • Low profile WLAN card
    • Various components can be replaced from this stage.
  4. Dell Latitude E5430 Hard Drive Replacement, Unscrew the Hard Drive from the Caddy: 步骤 4 中的图像 1,1
    • Remove the four Phillips head screws surrounding the hard drive in the caddy.
    • There are two more screws on the other side of the hard drive.
  5. Dell Latitude E5430 Hard Drive Replacement, Done!: 步骤 5 中的图像 1,1
    • Congratulations, you've done it!
结论
After you have installed your new hard drive or SSD, repeat the process in reverse.
5等其他人完成本指南。
Sam
于02/24/17注册
648 声望
创作了3篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 33
总计 3,612
