跳转到主内容
Dell Latitude E5410 keyboard Replacement
你所需要的
  1. Dell Latitude E5410 keyboard Replacement, Dell Latitude E5410 keyboard: 步骤 1 中的图像 1,1
    • Position laptop so that the LCD screen is aligned directly flat and parallel to the keyboard section of the laptop.
  2. Dell Latitude E5410 keyboard Replacement: 步骤 2 中的图像 1,1
    • Use the iFix it Opening Tool to remove the flat section located directly above the keyboard, as seen in picture.
  3. Dell Latitude E5410 keyboard Replacement: 步骤 3 中的图像 1,1
    • Locate two internal screws (pictured) under removed section.
    • Use the Phillips screwdriver to remove both screws.
    • The screw in the middle is 3.85mm and the screw on the left is 8.66mm.
  4. Dell Latitude E5410 keyboard Replacement: 步骤 4 中的图像 1,1
    • Firmly grip the upper section of the keyboard.
    • Pull on the keyboard in an upwards motion.
    • The keyboard should be successfully removed.
结论
3等其他人完成本指南。
一条评论
thanks man but its super easy not moderat i have 16 years old and i remove my keybord...
ZendomXGamer ZXG - 回复
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 28
总计 5,171
