本指南有最近更改,您可查看未经巡查的最新版本。
你所需要的
Losen all four screws and remove the backpanel.
Remove the backpanel with a spudger. Start out as in the second photo to prevent the plastic from breaking. Work you're way around the panel to remove it.
Now you can upgrade or change the memory.
NOTE: If the laptop doesnt boot after the upgrade, make sure the ram is fully inserted. Still doesnt boot? Try another memory stick.
另外一个人完成了本指南。
