跳转到主内容
Dell Latitude E4300 Memory (RAM) Replacement
你所需要的
    • Shut down your computer. Disconnect all power sources before opening the computer cover or panels.
    • Remove the battery from the computer.
    • Your computer has two user-accessible SODIMM sockets, referred to as DIMM A and DIMM B, both accessed from the bottom of the computer. The socket closest to the system board, DIMM A, always contains a memory module. The DIMM B socket may contain an additional module for improved system memory performance.
    • If the module in the DIMM A socket must be replaced and DIMM B is installed, you must remove DIMM B first.
    • If your computer has only one memory module, install the memory module in the socket labeled "DIMM A."
    • If you remove your original memory modules from the computer during a memory upgrade, keep them separate from any new modules that you may have, even if you purchased the new modules from Dell. If possible, do not pair an original memory module with a new memory module. Otherwise, your computer may not perform optimally.
  1. Dell Latitude E4300 Memory (RAM) Replacement, Turn computer upside down; loosen screws and remove memory cover.: 步骤 3 中的图像 1,1
    • Close the display and turn the computer upside-down.
    • Loosen the captive screws on the memory cover.
    • Remove the memory cover.
  2. Dell Latitude E4300 Memory (RAM) Replacement, Open up the retaining clips; remove the module.: 步骤 4 中的图像 1,1
    • To prevent damage to the memory module connector, do not use tools to remove or replace the memory module.
    • From the underside of the computer, the DIMM B socket is uppermost and DIMM A is closest to the system board.
    • Use your fingertips to carefully spread apart the retaining clips on each end of the memory module connector until the module pops up.
    • Remove the module by grasping it at the side edges and pulling it away from the connector. Place the module into anti-static packaging such as an anti-static bag.
    • Ground yourself by touching a metal part in the computer chassis.
    • Remove the memory module from its anti-static packaging.
  3. Dell Latitude E4300 Memory (RAM) Replacement, Align the module to the module edge connector slots; insert memory chip into the socket.: 步骤 6 中的图像 1,1
    • Grasping the module at the side edges, align the slot in the module edge connector with the key in the socket connector.
    • Slide the memory module into the socket connector at a 30-degree angle until it is fully seated.
    • Push the long edge of the memory module down until the retaining clips lock the module into place.
    • If the memory module is not installed properly, the computer may not boot properly. No error message indicates this failure.
    • Replace the memory cover and tighten the captive screws.
    • If the cover is difficult to close, remove the memory module and reinstall it. Forcing the cover to close may damage your computer.
    • Install the battery.
终点
另外一个人完成了本指南。
Hezekiah Brown
于02/11/21注册
6,169 声望
创作了49篇指南
团队
RampUP America, Inc. RampUP America, Inc. 的会员
Community
43 名成员
创作了1,985篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 8
总计 312
