跳转到主内容
Dell Latitude E4200 Keyboard Replacement
你所需要的
  1. Dell Latitude E4200 Keyboard Replacement, Power Button Panel: 步骤 1 中的图像 1,1
    • Open computer.
  2. Dell Latitude E4200 Keyboard Replacement: 步骤 2 中的图像 1,1
    • Slide any tool with a flat surface under the side bottom right corner of front panel and pry the front panel out of place.
    • A small flat head screwdriver would be an ideal tool to use during this step.
  3. Dell Latitude E4200 Keyboard Replacement: 步骤 3 中的图像 1,1
    • Once out of place, position your thumbs under the bottom of the panel and pull upwards.
  4. Dell Latitude E4200 Keyboard Replacement, Keyboard: 步骤 4 中的图像 1,1
    • Use a PH00 screwdriver to unscrew the screw.
  5. Dell Latitude E4200 Keyboard Replacement: 步骤 5 中的图像 1,2 Dell Latitude E4200 Keyboard Replacement: 步骤 5 中的图像 2,2
    • Use your hands to gently lift the keyboard from the device.
  6. Dell Latitude E4200 Keyboard Replacement: 步骤 6 中的图像 1,1
    • Gently turn the keyboard over.
  7. Dell Latitude E4200 Keyboard Replacement: 步骤 7 中的图像 1,1
    • Be careful not to disconnect the keyboard connector.
  8. Dell Latitude E4200 Keyboard Replacement: 步骤 8 中的图像 1,1
    • Use a flat head screwdriver to flip the keyboard connector up. This will allow you to disconnect the keyboard and remove it.
  9. Dell Latitude E4200 Keyboard Replacement: 步骤 9 中的图像 1,1
    • Completely lift the keyboard from the device, as they are now disassembled.
结论
3等其他人完成本指南。
团队
Baylor, Team 5-6, Williams Spring 2015 Baylor, Team 5-6, Williams Spring 2015 的会员
BU-WILLIAMS-S15S5G6
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 15
总计 4,312
