本指南有最近更改,您可查看未经巡查的最新版本。
简介
Backup all important data files on the system.
Remember opening your laptop may void the warranty, so perform this at your own risk and our help.
你所需要的
Perform a complete system backup and shutdown the computer.
Unplug the charger and remove the battery.
Remove the battery by sliding the lock tab (outlined in red) and use the other hand to remove the battery.
Remove the cable that connects the speaker (small rectangle) to the frame by pulling straight out. The cable is located to the left of DDR2 DIMM A.
Remove the cable that connects the track pad (large rectangle) to frame by pulling straight out. The cable is also located to the left of DDR2 DIMM A.
There are 7 screws that need to be removed around edge of Motherboard. 4 of the screws are 3.73mm length x 1.90mm width
Remove the PCMCIA connector from the motherboard.
Turn the laptop on the side and remove 2 female hex screws from video card and 2 posts from serial port using socket driver (3/16 socket) All hex screws are 10.23mm x 2.66mm size
14等其他人完成本指南。
2条评论
i used this to replace the thermal paste its really easy to follow simple steps
