跳转到主内容
Dell Latitude D820 Hard Drive Replacement
你所需要的
  1. Dell Latitude D820 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the charger from the laptop.
    • Turn the laptop over and locate the battery slide lock. Slide the switch and gently lift up the battery.
    • If you are replacing other components, leave the battery out.
    • If you are only replacing the battery, reverse the steps to install a new battery.
  2. Dell Latitude D820 Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 1,2 Dell Latitude D820 Hard Drive Replacement, Hard Drive: 步骤 2 中的图像 2,2
    • Locate the hard drive compartment in the lower right hand corner of the bottom of the laptop. It is located next to the empty battery compartment. The words 'Strike Zone' are engraved on it.
    • Locate and remove three philips head screws. These screws measure 3.55mm in length and 2.93mm in width with a fine thread.
    • Gently slide grip pad to the right and the hard drive should slide out.
    • Reverse the process to install new hard drive.
结论
Removing and replacing the hard drive
2等其他人完成本指南。
Elizabeth
于09/06/14注册
423 声望
创作了2篇指南
团队
Pasco Hernando, Team 1-2, Prince Fall 2014 Pasco Hernando, Team 1-2, Prince Fall 2014 的会员
PHSC-PRINCE-F14S1G2
10 名成员
创作了7篇指南
一条评论
You also need to unscrew the grip pad from the old hd and screw it onto the new one.
Sue - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 17
总计 3,439
