跳转到主内容
Dell Latitude D820 Battery Replacement
你所需要的
  1. Dell Latitude D820 Battery Replacement, Battery: 步骤 1 中的图像 1,1
    • Remove the charger from the laptop.
    • Turn the laptop over and locate the battery slide lock. Slide the switch and gently lift up the battery.
    • If you are replacing other components, leave the battery out.
    • If you are only replacing the battery, reverse the steps to install a new battery.
结论
3等其他人完成本指南。
Elizabeth
于09/06/14注册
423 声望
创作了2篇指南
团队
Pasco Hernando, Team 1-2, Prince Fall 2014 Pasco Hernando, Team 1-2, Prince Fall 2014 的会员
PHSC-PRINCE-F14S1G2
10 名成员
创作了7篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 8
总计 1,321
