跳转到主内容
Dell Latitude D630 Wireless Card Replacement
你所需要的
  1. Dell Latitude D630 Wireless Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 Wireless Card Replacement: 步骤 2 中的图像 1,1
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 Wireless Card Replacement, Keyboard: 步骤 3 中的图像 1,3 Dell Latitude D630 Wireless Card Replacement, Keyboard: 步骤 3 中的图像 2,3 Dell Latitude D630 Wireless Card Replacement, Keyboard: 步骤 3 中的图像 3,3
    • With the battery removed, turn the laptop face up and open the lid a complete 180 degrees.
    • Using a plastic opening tool, pry off the corner of the keyboard bezel by undoing the tab.
    • Once you've removed the corner of the bezel, you can use your hands to slowly, but with moderate force, pull the rest of the bezel slightly up and towards you to release the remaining tabs.
  4. Dell Latitude D630 Wireless Card Replacement: 步骤 4 中的图像 1,1
    • Remove the three 3mm Phillips #0 screws securing the keyboard.
  5. Dell Latitude D630 Wireless Card Replacement: 步骤 5 中的图像 1,2 Dell Latitude D630 Wireless Card Replacement: 步骤 5 中的图像 2,2
    • Slowly bring the keyboard up and fold it back onto the touchpad.
    • Be careful not to pull too hard or too far when folding over the keyboard. The keyboard is still connected to the motherboard by a short ribbon cable.
  6. Dell Latitude D630 Wireless Card Replacement: 步骤 6 中的图像 1,2 Dell Latitude D630 Wireless Card Replacement: 步骤 6 中的图像 2,2
    • Use a plastic opening tool to unhook the blue latch that secures the keyboard cable.
    • Using the blue tab, pull the keyboard cable connector from its socket on the motherboard.
  7. Dell Latitude D630 Wireless Card Replacement, Wireless Card: 步骤 7 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the black and white cables on the wireless card with the tweezers by pulling upward.
    • The black has already been removed in the image to show before and after.
  8. Dell Latitude D630 Wireless Card Replacement: 步骤 8 中的图像 1,1
    • Push on the tabs indicated in the picture until the card pops up slightly then pull the card out at an angle.
结论
To reassemble your device, follow these instructions in reverse order with your new wireless card.
5等其他人完成本指南。
Jon Amireh
于01/17/13注册
1,698 声望
创作了8篇指南
团队
Cal Poly, Team 6-1, Johann Winter 2013 Cal Poly, Team 6-1, Johann Winter 2013 的会员
CPSU-JOHANN-W13S6G1
4 名成员
创作了10篇指南
2条评论
1) You don't have to disconnect the keyboard cable to replace the WiFi card.
2) You may have three wires connected to the wifi card, disconnect all three
3) If your new wifi card has three sockets the grey lead heading off towards the front of the machine is for the middle socket; it has a plastic wrapper that can be slid off.
Robert de Bath - 回复
What type of Wi-Fi card is needed to be ordered to make it dual-band AC compatible?
Jake Brown - 回复
添加评论
浏览统计数据:
过去 24 小时: 5
过去 7 天: 17
过去 30 天: 50
总计 11,139
