跳转到主内容
Dell Latitude D630 Hard Drive Replacement
你所需要的
  1. Dell Latitude D630 Hard Drive Replacement, Battery: 步骤 1 中的图像 1,1
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. Dell Latitude D630 Hard Drive Replacement: 步骤 2 中的图像 1,1
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
  3. Dell Latitude D630 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 1,3 Dell Latitude D630 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 2,3 Dell Latitude D630 Hard Drive Replacement, Hard Drive: 步骤 3 中的图像 3,3
    • Position the closed laptop upside down.
    • Unscrew the screw closest to the hard drive opening and the one diagonally to the right. This will loosen the hard drive.
    • Do not unscrew this screw!
  4. Dell Latitude D630 Hard Drive Replacement: 步骤 4 中的图像 1,1
    • Place thumb on the hard drive cover and get a firm grip.
    • Pull the hard drive out slowly to avoid any further damage to the laptop.
  5. Dell Latitude D630 Hard Drive Replacement: 步骤 5 中的图像 1,2 Dell Latitude D630 Hard Drive Replacement: 步骤 5 中的图像 2,2
    • Unscrew the screw on the right side to remove cover.
    • Slide cover off.
结论
17等其他人完成本指南。
Savi Chavan
于03/12/14注册
979 声望
撰写一个指南
团队
UMass Dartmouth, Team 1-4, Cichon Spring 2014 UMass Dartmouth, Team 1-4, Cichon Spring 2014 的会员
UMASSD-CICHON-S14S1G4
3 名成员
创作了1篇指南
4条评论
Dell latitude 2RHczd1
C Chandler - 回复
I appreciate the guide my good sir. Very helpful.
Matt Erti - 回复
Is the hard drive replaceable to 2.5-inch SSD? for example Kingston a400.
Aduh - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 28
总计 15,329
