跳转到主内容
当前版本的文档还未经巡查,您可以查看最新的已查核版本
你所需要的
  1. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 1 中的图像 1,1
    • Shutdown the computer, detach it from any power source, and make sure the laptop is closed with its latch securely shut.
    • Turn the laptop over so its bottom is facing you.
    • The laptop pictured comes with a palm rest attached to the battery case. This part may not be present on your laptop. Regardless, the steps are exactly the same.
  2. 这个步骤还没有翻译 帮忙翻译一下
    : 步骤 2 中的图像 1,1
    • Using two index fingers, slide the battery latches outward.
    • While still holding the latches out, use your thumbs to slide the battery out towards you.
    • Once the battery is dislodged, you can let go of the latches and remove the battery.
终点
12等其他人完成本指南。
Justin Ng
于01/24/13注册
138 声望
撰写一个指南
团队
Cal Poly, Team 6-1, Johann Winter 2013 Cal Poly, Team 6-1, Johann Winter 2013 的会员
CPSU-JOHANN-W13S6G1
4 名成员
创作了10篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 14
过去 30 天: 27
总计 9,038
