跳转到主内容
Dell Latitude D620 Hard Drive Replacement
你所需要的
    • First, as always, power down the laptop and remove the battery., This can be done by pulling the two tabs above the battery and then simply pulling out the battery.
  1. Dell Latitude D620 Hard Drive Replacement, Unscrew the drive bay: 步骤 2 中的图像 1,1
    • Now, remove the two drive screws, located in the bottom right of the laptop. These are helpfully labeled with a cylindrical hard drive icon.
  2. Dell Latitude D620 Hard Drive Replacement, Removing the drive bay: 步骤 3 中的图像 1,1
    • Now, simply pull the hard drive out
  3. Dell Latitude D620 Hard Drive Replacement, Removing the drive from its cage: 步骤 4 中的图像 1,1
    • Now, remove the drive from its cage by removing the single screw holding it in. See the picture for help
结论
To reassemble your device, attach your drive to the bay and follow these instructions in reverse order.
5等其他人完成本指南。
James Martin
于03/19/16注册
231 声望
撰写一个指南
2条评论
can i install 1 tr wd sshd 2.5 inch on dell d620?
does it support it??
please answer my quastion.
pouranvary@gmail.com
mohammad - 回复
can my dell d620 support 1 tr sshd?
does it support 1 tr hard?
please answer my quastion:
mohammad - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 51
总计 2,715
