跳转到主内容
Dell Latitude D620 Display Replacement
你所需要的
  1. Dell Latitude D620 Display Replacement, Keyboard: 步骤 1 中的图像 1,1
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
  2. Dell Latitude D620 Display Replacement: 步骤 2 中的图像 1,3 Dell Latitude D620 Display Replacement: 步骤 2 中的图像 2,3 Dell Latitude D620 Display Replacement: 步骤 2 中的图像 3,3
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 Display Replacement: 步骤 3 中的图像 1,1
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 Display Replacement: 步骤 4 中的图像 1,1
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 Display Replacement: 步骤 5 中的图像 1,2 Dell Latitude D620 Display Replacement: 步骤 5 中的图像 2,2
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 Display Replacement: 步骤 6 中的图像 1,2 Dell Latitude D620 Display Replacement: 步骤 6 中的图像 2,2
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 Display Replacement: 步骤 7 中的图像 1,1
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
  8. Dell Latitude D620 Display Replacement, Display: 步骤 8 中的图像 1,1
    • Detach cables that connect the display to the body of the laptop
  9. Dell Latitude D620 Display Replacement: 步骤 9 中的图像 1,1
    • Disconnect the black cable attached to the motherboard
  10. Dell Latitude D620 Display Replacement: 步骤 10 中的图像 1,2 Dell Latitude D620 Display Replacement: 步骤 10 中的图像 2,2
    • Close the laptop lid
    • Turn the laptop over onto its backside
    • Unscrew the two screws shown in the picture using a #00 screwdriver
  11. Dell Latitude D620 Display Replacement: 步骤 11 中的图像 1,2 Dell Latitude D620 Display Replacement: 步骤 11 中的图像 2,2
    • Face the laptop's back ports towards you
    • Unscrew the two screws labeled in the picture using a #00 screwdriver
  12. Dell Latitude D620 Display Replacement: 步骤 12 中的图像 1,1
    • Turn the laptop over again so it's right-side up
    • Open the display, and pull the display up and out of the laptop's body
  13. Dell Latitude D620 Display Replacement: 步骤 13 中的图像 1,1
    • Remove the circular rubber pads as outlined in the picture using a spudger
  14. Dell Latitude D620 Display Replacement: 步骤 14 中的图像 1,1
    • Unscrew the screws that were under the rubber circles using the #00 screwdriver
  15. Dell Latitude D620 Display Replacement: 步骤 15 中的图像 1,1
    • Carefully use a spudger to work around the edge of the screen to lift off the plastic cover
    • Be very careful while doing this as the plastic snaps easily
  16. Dell Latitude D620 Display Replacement: 步骤 16 中的图像 1,1
    • Remove the screws outlined in the picture
  17. Dell Latitude D620 Display Replacement: 步骤 17 中的图像 1,1
    • Carefully lift the LCD screen out of its casing
结论
19等其他人完成本指南。
Miguel Wong
于04/15/10注册
562 声望
创作了3篇指南
团队
Cal Poly, Team 24-35, Regan Spring 2010 Cal Poly, Team 24-35, Regan Spring 2010 的会员
CPSU-REGAN-S10S24G35
4 名成员
创作了4篇指南
一条评论
Check out this replacement screen at a great price on bcdelectrostore.com
http://www.bcdelectrostore.com/magento/l...
bob harris - 回复
添加评论
浏览统计数据:
过去 24 小时: 7
过去 7 天: 10
过去 30 天: 54
总计 33,231
