当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Locate the notch under the cover at the top of the keyboard
Using the spudger as a lever, lift the plastic covering
Carefully remove the rest of the covering from right to left
Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
