简介
Replacing a defective modem is fairly simple and will help your computer in connecting to networks requiring a modem.
配件
无需配件。
  1. Remove the 3.9 mm Phillips #1 screw from the battery compartment. Remove the 3.9 mm Phillips #1 screw from the battery compartment.
    • Remove the 3.9 mm Phillips #1 screw from the battery compartment.
  2. Locate the laptop battery release button lock Push the battery release in the direction of the arrow, and pull upward. Push the battery release in the direction of the arrow, and pull upward.
    • Locate the laptop battery release button lock
    • Push the battery release in the direction of the arrow, and pull upward.
  3. Remove the battery from its compartment.
    • Remove the battery from its compartment.
  4. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem. Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem. Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem.
    • Remove the 3.9mm screw with a Philips #1 screwdriver containing the modem.
  6. Lift and remove the lid. Lift and remove the lid.
    • Lift and remove the lid.
  7. Remove the 3.9mm Philips #1 screw on top of the modem. Remove the 3.9mm Philips #1 screw on top of the modem.
    • Remove the 3.9mm Philips #1 screw on top of the modem.
  8. Pull on the white tab to remove the modem Remove the cable going to the modem. Remove the cable going to the modem.
    • Pull on the white tab to remove the modem
    • Remove the cable going to the modem.
结论
另外一个人完成了本指南。
Jose Chavez
于2014年01月26日注册
113 信誉积分
撰写一个指南
团队
Cal Poly, Team 6-24, Maness Winter 2014 Cal Poly, Team 6-24, Maness Winter 2014 的会员
CPSU-MANESS-W14S6G24
4 名成员
创作了5篇指南
I have manufacturing mode problem can you help me??
Mod - 回复
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 10
总计 1,285
