跳转到主内容
Dell Latitude D600 Wireless WiFi Card Replacement
你所需要的
  1. Dell Latitude D600 Wireless WiFi Card Replacement, Battery: 步骤 1 中的图像 1,1
    • Find the battery
  2. Dell Latitude D600 Wireless WiFi Card Replacement: 步骤 2 中的图像 1,2 Dell Latitude D600 Wireless WiFi Card Replacement: 步骤 2 中的图像 2,2
    • Pull the tab to release the battery
  3. Dell Latitude D600 Wireless WiFi Card Replacement: 步骤 3 中的图像 1,1
    • Pull the battery out
  4. Dell Latitude D600 Wireless WiFi Card Replacement, Wireless WiFi Card: 步骤 4 中的图像 1,1
    • Use your screwdriver to unscrew and lift up the panel on the right labeled with a C
  5. Dell Latitude D600 Wireless WiFi Card Replacement: 步骤 5 中的图像 1,1
    • Pull off the two wires connected to the wireless card
    • They should come off fairly easy
  6. Dell Latitude D600 Wireless WiFi Card Replacement: 步骤 6 中的图像 1,2 Dell Latitude D600 Wireless WiFi Card Replacement: 步骤 6 中的图像 2,2
    • Pull the two tabs away from the card and pull up on the intel card
    • Then pull it away from the holding slot to remove it
  7. Dell Latitude D600 Wireless WiFi Card Replacement: 步骤 7 中的图像 1,2 Dell Latitude D600 Wireless WiFi Card Replacement: 步骤 7 中的图像 2,2
    • When placing in your new wireless card, connect the two wires before inserting into the slot
    • Then line it up, put the card in at an angle and push down so the side tabs lock it into place
结论
6等其他人完成本指南。
Joseph
于07/16/14注册
1,497 声望
创作了5篇指南
一条评论
Hi,
dell latitude D600 Laptop
Can you please help me, I cant release my wireless card, by pulling the tabs on cards sides.?
It just doesn't release the card to pull out, is there any other way I can remove my card.?
Email me if you can .
robert.wilson407@ntlworld.com
Thanking you Rob
rob wilson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 2,633
