跳转到主内容
加入维修社区 - 创建账户
Dell Latitude D600 RAM (Main Memory) Replacement
你所需要的
  1. Dell Latitude D600 RAM (Main Memory) Replacement, Battery: 步骤 1 中的图像 1,1
    • Find the battery
  2. Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 2 中的图像 1,2 Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 2 中的图像 2,2
    • Pull the tab to release the battery
  3. Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 3 中的图像 1,1
    • Pull the battery out
  4. Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): 步骤 4 中的图像 1,2 Dell Latitude D600 RAM (Main Memory) Replacement, RAM (Main Memory): 步骤 4 中的图像 2,2
    • Find the panel underneath the microsoft product key sticker, the panel is labeled with an M
    • Unscrew the single screw above the M
  5. Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 5 中的图像 1,3 Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 5 中的图像 2,3 Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 5 中的图像 3,3
    • Pull off the panel to reveal the RAM
    • RAM is held in by two tabs, pull each tab to the side and the RAM will pop up
  6. Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 6 中的图像 1,1
    • Once the RAM is popped up, slowly pull it out of the slot
  7. Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 7 中的图像 1,3 Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 7 中的图像 2,3 Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 7 中的图像 3,3
    • To add or replace RAM, place the memory into the slot at an angle
    • Make sure you line it up correctly
    • If it is in correctly it should stay up at an angle by itself
    • Then push down in the middle until it clicks into place
  8. Dell Latitude D600 RAM (Main Memory) Replacement: 步骤 8 中的图像 1,1
    • The RAM should be secured by the tabs where the two semi circles are on the RAM
    • If it is not secure, just gently pull it out and try again, use the images to help you out
结论
6等其他人完成本指南。
Joseph
于07/16/14注册
1,497 声望
创作了5篇指南
1指南评论
Almost perfect: easy; clear;
Herman - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 34
总计 3,090
