简介
You can tell if your hard drive is broken if you get a 'hard drive missing/not detected' error upon computer startup. If this is the case, you need to buy a hard drive and replace the old one with it. Most hard drives can withstand being handled, but it is good to be careful with it nonetheless.
你所需要的
The hard drive will be located in the side of the laptop.
Unscrew the two bottom 6mm screws using Phillips #1.
另外一个人完成了本指南。
