跳转到主内容
Dell Latitude D430 Wireless Adapter Replacement
你所需要的
  1. Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: 步骤 1 中的图像 1,3 Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: 步骤 1 中的图像 2,3 Dell Latitude D430 Wireless Adapter Replacement, Wireless Adapter: 步骤 1 中的图像 3,3
    • Flip the laptop so you are able to see the bottom.
  2. Dell Latitude D430 Wireless Adapter Replacement: 步骤 2 中的图像 1,2 Dell Latitude D430 Wireless Adapter Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #00 screwdriver to remove the three screws that secure the small "L" shaped backplate.
  3. Dell Latitude D430 Wireless Adapter Replacement: 步骤 3 中的图像 1,1
    • Once all 3 screws have been removed, carefully remove the panel by grabbing the edges, and pulling up.
  4. Dell Latitude D430 Wireless Adapter Replacement: 步骤 4 中的图像 1,3 Dell Latitude D430 Wireless Adapter Replacement: 步骤 4 中的图像 2,3 Dell Latitude D430 Wireless Adapter Replacement: 步骤 4 中的图像 3,3
    • Identify the two pins connecting the wireless adapter to the motherboard. (The wireless adapter will say WLAN on it.)
    • Carefully pull up on each pin and remove them from the wireless adapter.
    • Note that there are no wires/cables connecting the wireless adapter to the motherboard.
  5. Dell Latitude D430 Wireless Adapter Replacement: 步骤 5 中的图像 1,2 Dell Latitude D430 Wireless Adapter Replacement: 步骤 5 中的图像 2,2
    • Pull back on the two metal tabs holding the wireless adapter down.
    • After the two metal tabs are pulled, the card will pop up.
  6. Dell Latitude D430 Wireless Adapter Replacement: 步骤 6 中的图像 1,1
    • Pull the wireless adapter out away from where it was connected.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 9
总计 499
