跳转到主内容
Dell Latitude 9510 USB and Headphone Jack Replacement
你所需要的
  1. Dell Latitude 9510 USB and Headphone Jack Replacement, Base Panel: 步骤 1 中的图像 1,1
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 USB and Headphone Jack Replacement: 步骤 2 中的图像 1,1
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
  3. Dell Latitude 9510 USB and Headphone Jack Replacement, Fan: 步骤 3 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the two 3 mm screws securing the fan.
  4. Dell Latitude 9510 USB and Headphone Jack Replacement: 步骤 4 中的图像 1,1
    • Place your fingernails behind the plastic tabs on the speaker's motherboard connector, then pull directly backwards, toward the wires, until the connector releases from its port.
    • Lift the fan up and out.
  5. Dell Latitude 9510 USB and Headphone Jack Replacement, Speakers: 步骤 5 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the four 2 mm screws from the speakers.
  6. Dell Latitude 9510 USB and Headphone Jack Replacement: 步骤 6 中的图像 1,1
    • Use a spudger to gently lever the speaker connector out of its port.
    • Lift the speakers up and out.
  7. Dell Latitude 9510 USB and Headphone Jack Replacement, USB and Headphone Jack Replacement: 步骤 7 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the four 3.5 mm screws.
  8. Dell Latitude 9510 USB and Headphone Jack Replacement: 步骤 8 中的图像 1,1
    • Place your fingernails behind each of the plastic tabs on the plug, and pull directly backward until the connector releases.
  9. Dell Latitude 9510 USB and Headphone Jack Replacement: 步骤 9 中的图像 1,1
    • Flip up the locking bars on the two ZIF connectors so they stand vertically, then gently remove the two ribbon cables connected to the IO daughterboard.
    • Lift the IO daughterboard up and out.
结论
Matthew D
于02/08/22注册
97 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 19
总计 187
