跳转到主内容
Dell Latitude 9510 Battery Replacement
你所需要的
  1. Dell Latitude 9510 Battery Replacement, Base Panel: 步骤 1 中的图像 1,1
    • Flip the device so that the base plate is facing you.
    • Use a Phillips #0 screwdriver to remove the nine 5.5 mm screws securing the base plate.
  2. Dell Latitude 9510 Battery Replacement: 步骤 2 中的图像 1,1
    • Wedge a spudger between the base plate and the chassis, then gently pry around the entire perimeter to release the base plate.
    • Remove the base plate.
  3. Dell Latitude 9510 Battery Replacement, Battery: 步骤 3 中的图像 1,1
    • Use a Phillips #0 screwdriver to remove the eight screws securing the battery.
  4. Dell Latitude 9510 Battery Replacement: 步骤 4 中的图像 1,1
    • Place a spudger behind a plastic tab on either side of the plug, then "walk" the connector out of its socket by gently pushing the plug toward the cables, alternating sides, until the connector releases.
    • Lift the battery up and out.
结论
David Cauley
于02/10/22注册
85 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 39
总计 744
