跳转到主内容
Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement
你所需要的
  1. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement, Base Panel: 步骤 1 中的图像 1,1
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: 步骤 2 中的图像 1,2 Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: 步骤 3 中的图像 1,3 Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: 步骤 3 中的图像 2,3 Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: 步骤 3 中的图像 3,3
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 4 中的图像 1,2 Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement, Wi-Fi Card: 步骤 4 中的图像 2,2
    • Remove the protective film located at the top left corner of the motherboard.
  5. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: 步骤 5 中的图像 1,2 Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: 步骤 5 中的图像 2,2
    • Use a Philips #00 screwdriver to remove the 2mm screw located above the wifi card.
  6. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: 步骤 6 中的图像 1,1
    • Remove the black and white wires located above the wifi card using a blue, plastic spudger.
  7. Dell Latitude 9410 2-in-1 Wi-Fi Card Replacement: 步骤 7 中的图像 1,1
    • Remove the Wifi card from its slot in the motherboard.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 14
总计 359
