跳转到主内容
Dell Latitude 9410 2-in-1 Motherboard Replacement
你所需要的
  1. Dell Latitude 9410 2-in-1 Motherboard Replacement, Base Panel: 步骤 1 中的图像 1,1
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 Motherboard Replacement: 步骤 2 中的图像 1,2 Dell Latitude 9410 2-in-1 Motherboard Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 Motherboard Replacement: 步骤 3 中的图像 1,3 Dell Latitude 9410 2-in-1 Motherboard Replacement: 步骤 3 中的图像 2,3 Dell Latitude 9410 2-in-1 Motherboard Replacement: 步骤 3 中的图像 3,3
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 Motherboard Replacement, Battery: 步骤 4 中的图像 1,2 Dell Latitude 9410 2-in-1 Motherboard Replacement, Battery: 步骤 4 中的图像 2,2
    • Use a Philips #00 screwdriver to remove the five 3mm screws that secure the battery.
  5. Dell Latitude 9410 2-in-1 Motherboard Replacement: 步骤 5 中的图像 1,3 Dell Latitude 9410 2-in-1 Motherboard Replacement: 步骤 5 中的图像 2,3 Dell Latitude 9410 2-in-1 Motherboard Replacement: 步骤 5 中的图像 3,3
    • Use a Philips #00 screwdriver to remove one 4.5 mm screw.
  6. Dell Latitude 9410 2-in-1 Motherboard Replacement: 步骤 6 中的图像 1,2 Dell Latitude 9410 2-in-1 Motherboard Replacement: 步骤 6 中的图像 2,2
    • Grip the battery cable near the plug and pull it straight out, in the direction of the cable.
  7. Dell Latitude 9410 2-in-1 Motherboard Replacement: 步骤 7 中的图像 1,2 Dell Latitude 9410 2-in-1 Motherboard Replacement: 步骤 7 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Use tweezers to gently move the speaker ribbon cable away from the bottom of the battery.
    • The ribbon cable is thin and fragile; handle it carefully.
    • The ribbon cable only needs to be moved so that the battery can be removed; do not completely remove the ribbon cable.
  8. Dell Latitude 9410 2-in-1 Motherboard Replacement: 步骤 8 中的图像 1,2 Dell Latitude 9410 2-in-1 Motherboard Replacement: 步骤 8 中的图像 2,2
    • Lift the battery out with two hands.
  9. Dell Latitude 9410 2-in-1 Motherboard Replacement, Motherboard: 步骤 9 中的图像 1,1
    • Use a Philips #00 screwdriver to remove the two 2 mm screws that secure the fan.
  10. Dell Latitude 9410 2-in-1 Motherboard Replacement: 步骤 10 中的图像 1,1
    • Disconnect the two ribbon cables connected to the motherboard by lifting the black ZIF tab and pulling the ribbon cables free.
  11. Dell Latitude 9410 2-in-1 Motherboard Replacement: 步骤 11 中的图像 1,1
    • Disconnect the two Wi-Fi card cables by prying them up and away from the press-fit connector.
  12. Dell Latitude 9410 2-in-1 Motherboard Replacement: 步骤 12 中的图像 1,1
    • Disconnect the small black wire from the mother board by pulling in the direction of the cable.
    • Disconnect the black and red wire from the motherboard, also by pulling the direction of the cable.
  13. Dell Latitude 9410 2-in-1 Motherboard Replacement: 步骤 13 中的图像 1,1
    • Use a Philips #00 screwdriver to remove the eight 3 mm screws that secure the motherboard.
结论
另外一个人完成了本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 14
总计 350
