跳转到主内容
Dell Latitude 9410 2-in-1 CMOS Battery Replacement
你所需要的
  1. Dell Latitude 9410 2-in-1 CMOS Battery Replacement, Base Panel: 步骤 1 中的图像 1,1
    • Ensure that the laptop is unplugged and powered off before beginning.
    • Place the laptop upside down on a flat surface.
  2. Dell Latitude 9410 2-in-1 CMOS Battery Replacement: 步骤 2 中的图像 1,2 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: 步骤 2 中的图像 2,2
    • Use a Phillips #00 screwdriver to loosen the ten captive screws.
    • The screws are permanently fastened to the base panel; do not attempt to remove them.
  3. Dell Latitude 9410 2-in-1 CMOS Battery Replacement: 步骤 3 中的图像 1,3 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: 步骤 3 中的图像 2,3 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: 步骤 3 中的图像 3,3
    • Carefully lift off the back panel.
  4. Dell Latitude 9410 2-in-1 CMOS Battery Replacement, CMOS Battery: 步骤 4 中的图像 1,3 Dell Latitude 9410 2-in-1 CMOS Battery Replacement, CMOS Battery: 步骤 4 中的图像 2,3 Dell Latitude 9410 2-in-1 CMOS Battery Replacement, CMOS Battery: 步骤 4 中的图像 3,3
    • Carefully peel back and remove the black tape around the top left corner of the motherboard.
  5. Dell Latitude 9410 2-in-1 CMOS Battery Replacement: 步骤 5 中的图像 1,3 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: 步骤 5 中的图像 2,3 Dell Latitude 9410 2-in-1 CMOS Battery Replacement: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • Grip the CMOS cable as close as possible to the plug, and gently pull directly backwards, in the direction of the cables, until the CMOS cable disconnects from the motherboard.
    • If the cable is hard to pull out by hand, use tweezers to get a better grip on the cable connector.
结论
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 7
过去 30 天: 31
总计 765
